Light Banging Noise In Tranny
Discussion in 'Transmission' started by propflux01, Sep 23, 2013.
  1. propflux01
    propflux01 Active Member
    217
    I have a question about Harley Trannies: I have 4 bikes between wife and myself. A Sporty, Road King, and 2 Ultras. Sporty is fine, Road king is fine, the '03 ultra is Fine, but the '06 seems to make sort of a banging noise in the tranny when its between accelerating and deceleration. Its like the gears are banging back and forth from excessive (?) play during that sweet spot of no torque on either side. Thing is, none of the other bikes do this. The only difference between all these is the Road king and the '03 Ultra have gear drive cams in them (by previous owners). I tried to adjust the primary thinking it was excessive play from that, but even adjusted tight it still does it. Now this weekend I was at the BBB rally in Fayetteville and got to try a 2014 CVO ultra with the water cooled heads. it did the same thing as the '06 does albeit not as loud.
    So, that being said, is this just something normal? If so, why does the other two bikes not do this?
    Also, same fluids in all trannies (Except the sporty).
  2. Bodeen
    4,647
    73
    222
    I am going to say that maybe its the compensator. Can you tell which side the noise is coming from? How many miles on the 06?
  3. HDDon
    5,562
    133
    236
    I believe your 03 and 06 have the same drive train. Both have 5 speed trans. and the old style compensator setup. Bodeen is probably right on the money here.
  4. propflux01
    217
    Actually just sounds below me, not really on any side. It also corresponds with the whine of the gears as well, if that makes sense. Almost acts like there is excessive play between the gears, hence why at first I thought it was excessive looseness in the primary chain. I put heavy shockproof in it and that quieted it down a bit, but what made me wonder if it was "normal" was the same noise in the 2014 ultra I test rode. The '06 has 18456 miles on it.
    [​IMG]
  5. 03ultra45385
    03ultra45385 Active Member
    146
    3
    Having had a compesator nut come loose over a period of about 20,000 miles and having had a dealer tell me it was a loose primary chain. i would ask does your engine shake more than most at an idle. If the answer is yes I wouldn't wait any longer to pull the primary cover and check your compesator nut.
  6. Bodeen
    4,647
    73
    222
    Your description still has me believing compensator but your mileage doesn't really add up. The earlier compensator's weren't as much a problem as the later. Might be worth opening up for an inspection.
  7. propflux01
    217
    The Engine does not shake excessive or anything, it is completely stock except for true duals. I guess it's time to take a look at the compensator and go from there.
    [​IMG]
  8. cortezc
    cortezc Member
    46
    Aww, that's just a arkie thing...they don't do that in Arizona, or Milwaukee either....
  9. Mavagrand
    Mavagrand Senior Member
    1,250
    12
    What is heavy shockproof? Im running formula+ in mine. Are you having clutch issues?
  10. Bodeen
    4,647
    73
    222
    I'm pretty sure he is talking about Redline with Shockproof. The original question about tranny. Therefore the Shockproof.
