lifter change?
Discussion in 'Harley Davidson Extreme Modification' started by B-1B_Guy, Feb 24, 2010.
  1. B-1B_Guy
    B-1B_Guy Junior Member
    556
    Guys,
    Building an 09 UC w/ 15K miles. Would you recommend changing tappets while the motor is tore down? I think the stock tappets are as good as the SE tappets so I'll stick w/ stock. Should I change them while I'm in there?
    Also, the service manual isn't real clear on the tappet install....it just says oil holes should face "inward". Does that mean both inlet/exhast tappets oil holes face towards the jugs? Appreciate any help.
    b1
  2. Chopper
    Chopper Senior Member
    1,632
    19
    I agree with you, unless you're doing a really rad cam and planning on alot of high rpm's the stock lifters sould be fine.
  3. 2006FXDCI
    2006FXDCI Active Member
    182
    I am running a woods 408-6 cam that is .650 lift, builder recomended "B" stock lifters. He said he has seen many SE and other lifters fail but never saw a set of "B" lifters fail. Also I think they recomend lifter changes at 20,000 miles so while I had it apart I would change them. If I remember right the "B" lifters were around $200.00, to me it was a small price to pay for peace of mind.
  4. barttoday
    barttoday Active Member
    111
    Oil holes towards the cylinder
  5. TQuentin1
    4,737
    142
    I would say change the lifters. May be a bit more cost, but why take the chance. When I did my roller chain conversion, the set of "B" lifters (18538-99B) was $94 for the four. Worth it.
  6. Bud White
    3,270
    reach into the holes where the tappets are and you will fill the oil feed slot face the holes to them on the 04 i did the holes were towards each other outers towards cyl and inner towards the outer
