Many have used LED bulbs in the lights on harleys but just an FYI for those who have.
The use of a LED bulb can set a code when used in directional lighting and the use in a brake light can cause cruise control problems in setting as well as a code set for the cruise.
If LED's are used in directional lights, a load equalizer is usually needed to maintain the proper function of the TSSM/TSM because of the lower draw of the LED's.
Load equalizers run very hot by design as they are "bleeding off" to ground through a resister the additional voltage necessary to obtain the proper load on the TSM/TSSM for it to function correctly. As a result of this, the life span isn't a long one in most cases (2-3 years) but there has been exceptions here.
