Lean Running Sporty
Discussion in 'Sportster Models' started by propflux01, Feb 17, 2010.
  1. propflux01
    propflux01 Active Member
    217
    Hello. My wife's 883 has had a problem since new (totally stock engine-wise) with what seems like a lean condition. When engine is cold, it stutters like mad for quite some time before the choke comes off. Once it warms it runs ok. When I pull the plugs they look to me like they are lean. I have messed with Suzuki bikes for years and have mechanical aptitude, just new to the HD way of doing things. I keep reading about stage one kits and jets kits and whatnot, would something like that help this bike? and what exactly is a stage kit, and what does it consist of? One note, she wanted it to sound less of a sewing machine and more like the big brothers we ride with, so we knocked the baffles out of the stock pipes. Sounds good, but the problem still remains, and wasn't affected by this change.
  2. Bud White
    3,270
    what year for one .. and knocking the baffles out creates more problems
    what else have you done to it .. is it carbed or EFI im guess carbed from what ya say if so some of the hd carb gurus will come buy and help
  3. Chopper
    Chopper Senior Member
    1,632
    19
    A stage 1 consist of a free breathing air cleaner, free flowing pipes and tuning. Rine hart make some great sounding slip-on's if you like a loud deep rumble or screamin eagle makes them street legal in sound but good perforamce and they also make a good air cleaner, if you like the stock cover or a more rad one called the heavy breather.
    You did not give the year so if it's carb harley has a tuner kit for it with easy to follow instructions and if it's fuel injected you have a choise of a download, a fueler or a tuner. here's a link to the screamin eagle catalog you can look through and if you search there is tons of info on the forum.
    2010 screamin’ eagle ® pro racing parts or download from mirror 2010 screamin’ eagle ® pro racing parts
  4. Joyflyin
    Joyflyin Experienced Member Staff Member Moderator
    5,811
    133
    202
  5. propflux01
    217
    Thank you for the replies. I am sorry I forgot the basics, it's a 2005 Carbed, with no other mods other than the baffles.
  6. propflux01
    217
    I will try this and get back with the results.
  7. NEWHD74FAN
    8,191
    98
    19
  8. propflux01
    217
    When i read this I came across this: "This can be done without removing the carb by rotating it slightly for better access to the screws and works best with a stage 1 intake kit. Using the stock air cleaner would cause a rich condition with this proceedure" My intake/Air Cleaner is stock, will this not work?
  9. NEWHD74FAN
    8,191
    98
    19
    Nope, stock air cleaner can flow more just by changing the element to K&N one that is free flowing, easily cleaned and lightly oil misted and your good to go, or upgrade to SE one if you want to add more flow and a bit of pizazz....
  10. Chopper
    1,632
    19
    I would change the whole air cleaner, I have used K&N filters in stock air boxes, while it's a much better filter, breathing was the same, you would benefit from a free breathing set up like the S/E or big sucker air filter.
