lazy starter
Discussion in 'Softail Models' started by jimibbo, Sep 11, 2011.
  1. jimibbo
    jimibbo New Member
    3
    I have a 96 springer softail my starter has been "slipping?" I pulled the starter and cleaned it and greased it good and the same for jack shaft put it back together but left primary cover off to see , the jackshaft engages and the starter spins (you can hear it ) but is lazy to turn the bike over ! any ideas ?
  2. HDDon
    5,542
    133
    229
  3. glider
  4. jimibbo
    jimibbo New Member
    3
    thanks for the reply
    is this repairable ? I am novice mechanic at best ! can i just rebuild the starter or do i need to bite the bullet ?
  5. TripleJ
    TripleJ Senior Member
    1,081
    8
    That depends on your situation. I new starter would around $325.00 and up and have a warranty while a rebuild would be maybe half that if you did it yourself. Replacing, although more expensive, would definitely be easier than rebuilding it IMO. Being its a 96 model I would consider that a good life out of a starter and would opt for the new unit.
    Motor Factory High Torque Starter | 383-734 | JP Cycles
  6. glider
    Yes it's repairable at less money than changing a starter. This is the part you need.
    [​IMG]
  7. jimibbo
    jimibbo New Member
    3
    thankyou all for the help and advice
    yippee skippee motorcycle back on the road !
    have had it apart together and back apart again again again n again
    cleaned greased starter had starter rebuilt finally read online forum to plainly stretch the spring on the jackshaft 1/4 inch so I drained the primary again removed it pulled the jackshaft stretched the spring replaced and just snugged the bolt (7 ft lbs) it has been working better than ever all day ! my next step would have been to replace the starter drive ! anyway I'm(EDITED) today!
    :tounge
    Please read and understand the info in this link below...
    [note]
    [/note]
