Key Fob
Discussion in 'Electrical' started by jbsox51, Nov 26, 2007.
  1. jbsox51
    jbsox51 Member
    13
    Has anyone removed their security system on a 07' or later.
    It is more of a hassle than its worth.:49:
  2. jbsox51
    jbsox51 Member
    13
    First off its just too dang big (the key fob) and secondly its probably just something else to leave me sittin' one day. I never seem to have it handy when I just need to move my bike to get at other stuff in my over crowded garage.
  3. Not Very PC
    Not Very PC R.I.P
    527
    If you can keep up with the key the fob should be no problem. :60:
    I personally have seen to many problems with HD alarms to ever trust one. :shock
  4. glider
    56
    I have the smart fob with mine and I have it on a belt clip that goes on my belt loop. I had the same problem with the fob being upstairs when I moved the bike, then the mad dash began when the alarm triggered. Now I put a hook right inside the basement coming in from the garage and that is the storage place for this belt clip with all the keys that are associated with the bike, like the rotor lock, ignition lock, and the key fob. Always handy just in case. As long as it is about 6-8 feet away from the bike , you are OK then.
    [​IMG]
  5. Not Very PC
    Not Very PC R.I.P
    527
    Same clip I carry my keys on.
  6. wildspirit97
    wildspirit97 Guest
    you can put your alarm in transport/storage mode so you can move it with out the alarm going off. to do that all you have to do is when you shut off your bike turn the ignition to accessory and press both turn signal buttons. your blinkers will flash once then let go and shut off your bike. then your blinkers will flash 3 times to indicate that it's in transport/storage mode.
    when thats set you can move your bike all you want with out the alarm going off. to get out of that mode all you have to do is turn the ignition switch on.
  7. acerider_01
    acerider_01 Member
    69
    I guess if you were dead set on removing system, wouldn't it be easier to just leave fob in your saddlebag. System would be a mute point and you wouldn't have to go through laborious task of removal. I wouldn't reccomend it, though.
