The K&N air filter for the Screamin’ Eagle assembly is available to upgrade the stage 1 already in use after K&N is not the supplier for the MOCO any longer.
It's part# HD-0800. This air filter replaces the Screamin’ Eagle air filter part number 29442-99B (Blue one). The HD 0800 will replace the following filters 29442-99A - B & C
The K&N filter can be identified with the number A063A4 stamped into the band of the filter.
The K&N can be found at Auto zone and other automotive stores but probably has to be ordered for you at a cost of about $43.
They have to enter the part number HD 0800 to access it.
K&N Customer Service 800-858-3333 or 951-826-4000. K&N does NOT make the blue banded filter.
The Stage 1 from the dealer came with the K&N a while back but now comes with a paper filter instead of the K&N which usually is not oilable but is cleanable.
The K&N needs a cleaner to service it K&N PN 99883-88T
and an oiling with K&N PN 99332-88T. Most automotive suppliers carry the service kits for the K&N filters
Cleaning Instructions K&N Air Filter Cleaning Instructions
DO NOT use compressed air or heat to dry the filter or you will damage the filter media.
The Arlen Ness stage 1 kit seen below uses a filter made by Airaid with a similar makeup as the K&N meaning it has the 4 layers of gauze material much like the K&N does and is cleanable and can be oiled.
Frequently asked questions about K&N filters...
K&N Frequently Asked Questions (FAQ)
When switching from the blue filter to the K&N filter, there is no further downloads or adjustments needed as some have been told by dealers.
Pre Filter Wraps...
For a pre filter wrap , try these people for a sock . 1-800-967-3450. Called Outer Wear.
Here's a link to the foam prefilters... http://www.knfilters.com/airforcewraps.htm
And another NON foam one... http://www.knpowersports.com/wraps.htm
Blue banded one that was found in the HD Stage 1 kits for a period of time. This filter is NOT cleanable or oilable and has been known to come apart and be injested into the engine.
Also a reply from Zippers performance http://www.zippersperformance.com/
Our upgrade to the Screamin Eagle filter is # 162-295 and is $74.95.
This filter is taller than a stock and does require the use of a round EVO
style cover.
Pre Filter Wraps...
style cover.
