Jim's Cartridge Fork Tool For 02 and up Baggers
Discussion in 'Chassis, Suspension and Front End' started by glider., Jul 24, 2007.
  1. glider.
    glider. BOT Machine
    18
    The 2002 and newer baggers with fairings have a cartridge in the left side fork tube which requires a special tool to disassemble and reassemble for the proper servicing of the fork oil.
    I believe in 06 on they went to the conventional left fork slider.
    Here's the tool for doing this, and it is available here.
    JIMS.....Performance Parts for Harley-Davidson Motorcycles
  2. TQuentin1
    4,747
    144
    OK, fine and dandy. That is the "right" way to do it. But I just want to change out the oil in the front fork. Right side is like it is supposed to be, and like my Dyna is on both sides. But the left, ...!! Now, what is the "quick and dirty" way to do this side?
  3. glider.
    glider. BOT Machine
    18
    Remove the fork leg ,invert and drain/refill it. No easy way unless you update the left fork to the non cartridge one like on the non fairing bikes.(road kings)
    Part # 46495-06 runs about $178 with a discount for the left leg.
  4. TQuentin1
    4,747
    144
    I can do the flip 'n flood if that gets the old oil out of the fork leg. Will try that.
    On the replacement part, what is the impact of replacing the current setup? Why did HD go with this setup? It seems unnecessarily complicated if a "normal" setup will work just as well.
  5. glider.
    glider. BOT Machine
    18
    I often wonder that myself. I believe they were trying to improve handling but the 06 and newer baggers went back to the conventional forks on both sides without the cartridges in the left side.
  6. TQuentin1
    4,747
    144
    OK. I think I will wait until the legs start to leak before replacing them with non-cartridge version.
    The original owner of this bike had it lowered by the dealership - front and back. I had to replace the rear air shocks a while ago, but have not been into the fork. With the fork lowered (I am assuming the standard lowering kit from HD), what is the air gap supposed to be? I do not have any paperwork on the Harley kit which I suspect would specify a different measurement.
  7. glider.
    glider. BOT Machine
    18
    Not sure what you are looking for here, are you referring to the PSI in the shocks? Different year bikes have different pressures, you would be safe with 5-10 lbs.
  8. TQuentin1
    4,747
    144
    No, I am talking (writing) about the air gap above the fork oil in the legs. Manual calls for 5 1/2" on the standard setup. Since I don't have the paperwork that came with the lowering kit, I am not sure what the "new" spec is for the air gap on the lowered legs.
  9. glider.
    glider. BOT Machine
    18
    I see what you are saying now. It's the measurement used in the cartridge side to refill. Best bet would be to contact the dealer, I believe the oil amount (measured) as opposed to inches is the same for a lowered fork as a regular one but I wouldn't want to give you bad info.
