free website stats program Intake Manifold Angles | Harley Davidson Forums
J
Jack Klarich
Guest
Heres a tech tip on aligning intakes, The Shovel head intake ports should be at 60 degrees, while the Evos should be at 30 degrees. you can use a 30/ 60 degree triangle to check the alignment before torquing the heads. Turn the heads so the triangle touches the intake ports in 2 places before final torquing:D
