installing an aftermarket Tach on 2009 DYNA
Discussion in 'Electrical' started by DaFach, Aug 28, 2015.
  1. DaFach
    DaFach New Member
    It used to be easy to install a tach as the coil once had positive and negative terminals, now my Dyna has a 4 pin connector going to the coil. Anyone know how to determine which wire or wires are positive and which are negative ?
  2. Jeff Klarich
    4,787
    103
    484
  3. Jack Klarich
    2007 Dyna 4 pin connector shows power wire slot A yellow/ green front coil slot d blue/ orange, rear coil slot yellow/ blue
  4. tourbox
    tourbox Senior Member
    1,885
    168
    Use to be a Pink wire for the Tach. under the Speedo. Don't know about the newer ones. Do you have a manual? It should show the pin conn. at the ECM for the tach. in the wiring diag. If you haven't bought the Tach. as yet make sure it is for Single Fire Ign.
    tourbox
  5. tourbox
    1,885
    168
    Looks like Jeff has your wiring covered.
    tourbox
