Inner Primary Repaint
Discussion in 'General Harley Davidson Topic' started by bikedelic, Dec 14, 2011.
  1. bikedelic
    bikedelic Member
    14
    While I've got my bike disassembled, I decided to repaint the inner primary. The old black wrinkle paint was chipped and flaking off pretty bad so I stripped it with paint stripper, masked off all the places I didn't want paint and repainted it with VHT Black Wrinkle paint (available at AutoZone).
    The instructions are on the can - it's pretty easy to do. Three really wet coats (be careful not to get any runs!). After letting the paint flash (start drying to the point where the solvents have evaporated and the paint is starting to set), I put it in my wife's oven at about 185* for an hour or so to cure it and get a good tight wrinkle. She came home while it was cookin! Not too happy, but she got over it.
    It came out great! When I put it all back together, it's going to look so good. I'll post some pics when I get a chance.
  2. Hoople
    Hoople Account Removed
    7,198
    34
    Sounds cool. I never used that paint. No primer is required. You can just spray smooth metal and go?
  3. bikedelic
    bikedelic Member
    14
    The instructions on the can don't call for primer and there was no primer when I stripped it so I didn't use any. The inner primary case is a sand-cast texture finish - fairly rough so it provides a good surface for the paint to stick to. Most of paint adheasion is mechanical so the sand-cast surface should sufficient. Time will tell. Some folks like to use a high temp BBQ grill paint for a base coat, but the temp rating for this paint doesn't really require it either. If I was doing the cylinders I would probably use the high temp first, but the primary doesn't get that hot.
  4. Hoople
    7,198
    34
    That's Good info to know because someday I will have to do mine. Tks!.
  5. R_W_B
    R_W_B Senior Member
    2,425
    23
    You've got all the ideas correct, but where are the pics ?
    You might wanna watch putting stuff in your kitchen oven. Not sure bout the paint buy I know for sure that powder coat gives off poisonous fumes that can permeate the oven afterwards. If I were you I think I would give that oven a good cleaning before you bake your next cake in it.
  6. SledDog
    SledDog Senior Member Staff Member Moderator
    2,120
    68
    88
    I need to do the inner on my Road King... Thanks for the great info!
  7. bikedelic
    bikedelic Member
    14
    Not to worry, low temp, just some VOC's floating around. It's due to have the clean button pushed anyway. I'll put up some pics as soon as I get the opportunity. :s
  8. horizonchaser
    horizonchaser Senior Member Contributor
    1,244
    A wise word of caution there R_W_B.
