Ignition Switch exploded view
Discussion in 'Touring Models' started by Widerider1950, Feb 17, 2011.
  1. Widerider1950
    Widerider1950 New Member
    After Taking apart the ignition switch on a 2011 FLHX unable to find an exploded view on how to reassemble the complete lock assembly and the plastic washer and lock nut under the Key Lock
  2. wannaride
    wannaride Active Member
    259
  3. drbillk
    drbillk Banned
    130
  4. oiler
    oiler Active Member
    150
  5. Dr. Dolittle
    6,404
    118
    29
    All excellent suggestions above.
    Sounds like you pulled one of my classic moves and took something apart with multiple pieces and only then realized you should have meticulously noted the order in which they go together. I can't tell you how many times I've done this! I'm learning, though.
  6. Joyflyin
    Joyflyin Experienced Member Staff Member Moderator
    5,825
    133
    208
    You aren't the only one Doc! Thank goodness I learned to take pictures of what I do...LOL
