free website stats program Ignition sensor | Harley Davidson Forums
Ignition sensor
Jonk777
Hello to all fellow members. In reference to the sensor on a 1990 Fxr 80 cubic inch engine,that is a stage one set-up. What sensor would be better to run a single or duel which correspondence with the coil set-up. What would be a safe limiter with that set-up in which most Harleys rev no more than 4500 thru 5500 rpms at that stage.:bigsmiley6:
Personally,
I'd run Single Fire if it can switch that way... A little More Spark firing ONE Plug then trying to have BOTH fired at the same time... One fire on the exhaust stroke is a wasted Spark... :s
I'd settle on a Safe 5,000 RPM setting...
IMO
Dyna ignition is a good value, offers separate timing for each cylinder, the better ones have adjustable rev limiters
