Hoople
Account Removed
If the low beam is burnt out in the headlight does that have any effect on no power to the passing/driving lights?
Not if the bike resembles the schematic from above. The yellow wire drives the low beam in the headlight. But even before the yellow wire reaches the low beam filament, there is a yellow tap wire which goes to connector # 74. That tap is what feeds the passing lights switch. So even without a headlight bulb installed, the passing lights will work.
Interesting note. I don't know if the passing lights turn with the forks or are mounted directly to the lower frame, but if they are mounted to the forks and turn with the bars, the short grounding pigtail at the triple tree is required and must make good contact for the passing lights to operate. The headlight bulb on the other hand has it's own dedicated ground wire (see black wire at the headlight bulb socket) and therefore does not need the short pigtail to be there. But both the left and right passing lights do not have a dedicated ground wire and are grounded through their mechanical mounting bolts and therefore need the pigtail if they turn with the bars.
