I have a 2007 Sportster XL1200 Custom, and I need to know if it is possible to adjust the idle speed being that it is Fuel Injected. Thanks!
Hey Guys Setting the idle speed on fuel injected bikes is a dealer function. They have to use the digital tech (special laptop computer) to set the idle speed and the ECM maintains it from there. If you are running a tuner like the SERT or PC III , that can be used to set the idle speed also. Other than that, call the dealer and they will usually do it for you while you wait.
