IAT Sensor
Discussion in 'Electrical' started by dynalarry, Apr 8, 2008.
  1. dynalarry
    dynalarry Member
    9
    I have to replace the IAT sensor on my 2006 Superglide Custom. My question is, do I have to remove the gas tank? The shop manual says only to remove the air filter and back plate, but I don't see how I can get to the sensor with the tank on. Thanks...
    You should be able to just unbolt the front and rear of the tank and prop up the rear of the tank. Don't lift it too hard or you will break the plastic fuel line connection under the tank. When you feel resistance, stop there.
