free website stats program IAT Sensor trouble code | Harley Davidson Forums
dynalarry
I've been getting trouble code PO113 (IAT sensor voltage open/high EFI) on my 2006 Superglide. I replaced the sensor and cleared the code but it returned. Any ideas on what else could be tripping this code? By the way, the bike runs great, but the check engine light is getting on my nerves. thanks....
It would require a volt meter and measure the voltage at the plug of the IAT, should be around 5 volts, and also check for ground. Check for the voltage first with the key on, then ground.
