I think my starter is going but not positive
Discussion in 'General Harley Davidson Topic' started by CVOlover, May 15, 2012.
  1. CVOlover
    CVOlover Member
    15
    I'm having and issue starting my bike on the initial push of the button,when I push the starter button it does not turn over, it simply makes somewhat of a grinding sound (like when its already started and u hit the starter button) . I'm hoping someone else on here has had a similar issue. It seems to start up no problem the second time every time . My bike is an 08 CVO road king with only 5000 miles on it, I'm hoping this is an easy fix
    thanks,
    Tyler
  2. Dr. Dolittle
    6,404
    118
    29
    Simple stuff first - are you still on your original battery? Load test your battery and check for good, clean, tight connections everywhere before you start tearing out your starter.
  3. Jeff Klarich
    4,783
    103
    483
    +1 on what Dr. Dolittle suggested, take a look in the self help section as well. Sounds like you could have a starter drive issue, do you have the extended warranty?
  4. CVOlover
    CVOlover Member
    15
    what do you mean by starter drive issue?
  5. Jack Klarich
    Load test the battery first, do you have a stock comp sprocket? H D had some problems with ring gears, do the simple things first starting at the battery
  6. Jeff Klarich
    4,783
    103
    483
    Not fully engaging or not engaging at all with the ring gear. Check out the self help section, alot of good info there.
  7. traveller
    traveller Member
    81
    check the power to the starter. If not enough amps to the starter the contacts will chatter, making a noise similar to what you heard. hope this helps.
  8. bodean46
    bodean46 Member
    19
    My problem is just paid 722.00 April 5th for a high torque starter that took dealer 10 days to get and now this morning, after a 20 mile ride, that high dollar starter won't engage, just click. Dealer got starer from Drag Specialties as well as a new Drag Specialties battery last year. Supposed to head out to Atwood Tennessee in the morning, but laying odds that won't happen.
  9. RoadKing61
    RoadKing61 New Member
    Thank you Dr. I had my battery checked was seriously low on cranking amps, 199 amps.
