R Rickyc New Member Jul 8, 2011 #1 There is no tension in my clutch handle. Prior to this the handle would inadvertently fall against the handle bar. I would push it back and it would begin working again. Now when I push it back it just falls again. Any suggestions?
HDDon Experienced Member Contributor Retired Moderators Jul 8, 2011 #2 My first look would be to lub the cable.
D dbmg Guest Jul 8, 2011 #3 HDDon said: My first look would be to lub the cable. Click to expand... Then perform a proper clutch adjustment...
R Rickyc New Member Jul 10, 2011 #4 Thanks, The nut came off the push rod!! ================================================== Thanks, Lube the cable but that was not the answer! It was the nut that came off the push rod! Last edited by a moderator: Jul 10, 2011
