I lost a brake pad
Discussion in 'Softail Models' started by barnak, Jul 1, 2009.
  1. barnak
    barnak Member
    51
    I was going for a cruise tonight when I notice that the rear break pedal was stiff, then I applied a good preassure on it, the rear break jammed and after stopping to investigate, I found that the inner brake pad was out of the calliper!, did this happened to any of you before?, I will call the dealer first thing tomorrow, it should be covert by warranty, and by the way, my ride have 17000km on it, 08 FLSTC, and the dealer where the last to performed work on it, I got the rear tire change 3000KM ago, thanks.
    50
    There was a thread on this just the other day. Try a search and you should be able to locate it.
