Well, I just put LED rear marker/brake/turn lights on my 2012 fatboy and put an LED brake light on, taking off an integrated turn signal/brake light LED light set.
Now when I put on either blinker the indicator on the gas tank panel flashes probably twice a second or so even though the external turn signals are both going about 1 flash per second, standard sedate speed.
I'm looking for a flasher relay that plugs into where the OEM flasher but don't know if what I have is what is available or if they changed the flasher module or what.
Boiled down, why is the indicator about twice as fast on the gas tank panel than is showing on front or rear turn signals and how can I fix it easiest.
Thanks
DanH
Thanks
DanH
