How to Check Breakers/Fuses?
Discussion in 'Electrical' started by BillZ, Jun 16, 2012.
  1. BillZ
    BillZ Member
    8
    Hey Gents...
    Still battling electrical problems with my 95 Low Rider. What is the procedure for checking the breakers/fuses? Also, with battery connected, I get a low voltage reading....like 10 volts. Frustration mounting!
  2. STEVE07
    4,125
    68
    85
    Have you had the battery load tested?
  3. BillZ
    BillZ Member
    8
    No....bike is currently dead in my garage....waiting for new turn signal module and connectors to arrive.
  4. R_W_B
    R_W_B Senior Member
    2,425
    23
    Pull the fuse from it's holder. Put your meter test leads across the fuse tabs. If the display still says infinity "&" or reads 0 then the fuse is open (blown).
    If the meter reading says a low number, most times less than 1 ohm (like 0.2 etc) then the fuse is good. If your meter has a continuity beeper, it will beep when you put it across the fuse.
    Fuses are cheap, if any doubt with a fuse buy a new one.
  5. Hoople
    Hoople Account Removed
    7,198
    34
    When measured where. If directly at the battery posts, 1st charge and then load test the battery.
