W wilkystreetglide Member Feb 4, 2009 #1 How many quarts of oil do I need for just an oil change for a 2006 Street Glide? Thanks.
rbmount Member Feb 4, 2009 #2 4 for the engine and 1 apiece for the tranny and primary, if you're using syn3.
G glider Veteran Member Feb 4, 2009 #3 4-1 & 1 but use compartment specific oils. Oil Suggestions For Harleys - Harley Davidson Community
G glider Veteran Member Feb 4, 2009 #5 wilkystreetglide said: Thanks for the help. I plan on getting HD Syn3. Click to expand... For the price of the semi synthetic syn 3 there are MUCH better choices in a full synthetic sometimes even for less money too.
mrkihn Active Member Feb 4, 2009 #6 Manual for my 09 street glide says 1.4 qt for primary. has there been a change from older models.?? My 05 springer said 1qt
G glider Veteran Member Feb 4, 2009 #7 When they went to the 96 engines, that's where the primary amount increased to 38 ounces.
Jammr Active Member Feb 4, 2009 #8 wilkystreetglide said: Thanks for the help. I plan on getting HD Syn3. Click to expand... As Glider said, there are MUCH better choices out there. I use Amsoil products only. 20W50 in the engine & primary and 75W110 gear lube in the tranny. I've found that almost everyone you ask will give you a different answer, so, good luck. Jammr
