Horn switch cap spring
Discussion in 'Touring Models' started by Lucy, Jan 17, 2009.
  1. Lucy
    Lucy Active Member
    102
    I'm replacing the switch caps on my 08 Road King. While I was removing the stock switch caps a small spring fell out from under the horn cap. Can anyone tell me how it needs to be oriented under the new cap. The diagram I have does not show the spring.
    Lucy
    Try looking under the cap, there should be a retention pin that holds it in place under the cap. It's only purpose is to return the button to the off position so it shouldn't be hard to understand the positioning of the spring.
