hiccup @ cruise speed
Discussion in 'Engine, Fuel and Exhaust' started by harleyreb, Mar 7, 2010.
  1. harleyreb
    harleyreb Member
    Got an 04 flht carburated bike that just started to hiccup at constant cruising speed. only happens when throttle is bareley cracked. anyone got ideas as to why?
  3. prodrag1320
    prodrag1320 Account Removed
    86
    just a little on the lean side,hapen more in colder weather?
  4. Billbo
    Billbo Junior Member
    717
    8
    I am NOT the HD mechanic -- but, my 01 Heritage battery went dead one day and I jumped it off and while driving home, my engine (EFI) acted the same way. would hicup while holding speed ~ 40-50 or so. The throttle was just barely open enough to maintain speed. -- solution - had the HD folks install new battery! No more hicups!
    You might just want to check out your battery. to check it out is free.
    Bill
  5. Jack Klarich
    Sounds like the lean hicup here
  6. Chopper
    Chopper Senior Member
    1,632
    19
    If you haven't changed intake or exhaust the jetting would not have changed so you might look for a restriction in the carb, or posably old gas or intake leak? A little history leading up to the hiccup might help find a cure.
  7. jaxdwg
    jaxdwg Active Member
    209
    3
    As chopper said, a little more background would help. That being said, I had that problem since new. After talking with others I put in a n65c needle and that fixed the hiccup, even on cold days
