chunngle
OK I have been swamped at work and have not had a lot of time to diagnose or to get on here to post. Here is an update. After replacing the fuel regulator housing the bike has been running much better. It still has the hard start issues. Took it out for a long ride one evening and noticed when oil temps were around 275 degrees and I got on it to pass a truck on the freeway that the speedometer quit working. When I pulled off the freeway the bike idled very low and rough. When I stopped I checked codes and got a P0501 code(VSS Low EFI). Reset code and let bike sit and cool off. It ran good on the way home.
Next day checked primary fluid and noticed the burnt smell. Exposed stator and found no burnt coils but one of the output wires was frayed bad where it attaches to the stator. Replaced stator and the bike seemed to run better but still has the hard start issues.
Took it for a good long day ride yesterday and it ran much better until once again the oil temps reached the 275 degree range and then the speedometer quit again when getting on it good. This time the code was U1016 (Loss of ECM Serial Data, Vehicle Speed, Vehicle Inhibit Motion or Power train Security Status TSM/TSSM). Reset code and let bike cool off and it ran good going home.
The P1353(loss of combustion to front cylinder) code has not showed back up but now codes associated with the Vehicle Speed Sensor. I dont know if it is purely coincidental but both times now it has been when the temps are high and at heavy acceleration. Just a thought but I do have an aftermarket speedometer calibration unit attached to the VSS.
I have an appt at the dealer on Tuesday. Does anyone have any suggestions before I drop big bucks on the dealers diagnosis?
