Help ! I've just ruined my bike
Discussion in 'General Harley Davidson Topic' started by bikerdude, May 27, 2010.
  1. bikerdude
    bikerdude Member
    10
    So , I've just bought this Fatboy ...
    Came with Stage 1 already done ...
    Vance Hines Ace looking & sounding pipes...
    Thing is I rode it with my old synthetic gear on & whilst stood at a light I noticed my R leg a bit warm .... never mind & off I go ...
    I get home & my inner leg clothing is now welded to the lovely V&H pipes , which I have to say does detract just a little ...
    Have I ruined my bike or are you guys out their going to tell me how I can get the welded plastic off of the pipes & restore her to her former glory ....
    Please ... I am a desperate man ....
    Don't get the oven cleaner on any other painted parts either.
    You also may dissolve it with some Lacquer thinners too.
  3. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    I have had this work long ago.... Probably not as Bad a your mess....
    Get pipes normal hot after ride... Keep running and Immediately put a Ice cube onto the plastic stuff and it May crack and pop off... Use a rag holding the ice directly on the spot of plastic... If this works , please report back here....
    Hoping to Hear from you!
  4. jaceddie
    jaceddie Junior Member
    928
    I think Hobbit has you covered here. Oven cleaner works great, but be careful not to get on painted surfaces.
  5. rklew
    rklew Active Member
    172
    Yep.! :s
  6. Randall K. Wilson
    Randall K. Wilson Junior Member
    535
    I wear tall boots with the cuff of my pants-leg tucked down in them.:s
  7. LarryC08
    LarryC08 Active Member
    141
    I found that a hand cleaner called Fast Orange works awesome. Had horrible rain gear stains and scuff marks on the UC pipes, used a little hand cleaner and pipes (heat shields) came out looking like new. I used Oven cleaner before and it does do the job but found Fast Orange way faster and did a better job JMO!!!
    Take care and ride safe eh!!!:D
  8. hntwrobin
    hntwrobin Active Member
    236
    0000 steel wool not abrasive so it damages pipes and will remove the stuff.
  9. Iceman24
    Iceman24 Well-Known Member
    3,266
    23
    No worries...nothing a little warm-up & butter knife won't fix. Now put away those 80's parachute pants & get some chaps...;)
  10. NEWHD74FAN
    8,191
    98
    19
    Larry's post in #8 was partly correct, use GoJo hand cleaner with NO PUMICE (it is in the blue and white container for couple bucks)...works great at removing "baked on" stuff on your pipes (when warm) with out damaging or "swirling" the chrome. Learned to use this way back in auto shop in the 70's...have to say if you want your hands clean after a dirty job, add a bit of Boraxo to the GoJo and your hands will look like you did not work on your vehicle.
