Help identifying this leak
Discussion in 'Softail Models' started by livestrong, Apr 8, 2011.
  1. livestrong
    livestrong New Member
    4
    I recently purchase an 05 heritage deluxe FLSTNI. It had 3500 original miles and now has 4100. I noticed the leak spot is getting bigger. It seems to be leaking/dripping from around the air assembly or behind it and looks like gas, but not sure. Does anyone have a idea of what the problem might be? I have replaced the two rubber hoses that run into the back of the air assembly that are common to rot. It has a stage1 scream eagle. Thanks in advance
  2. HDSickness
    HDSickness Banned
    418
    Does it smell like gas?
  3. livestrong
    4
    Can't really smell anything? And when I run my finger over it's dry. Thanks for the reply
  4. JBC2565
    JBC2565 Junior Member
    582
  5. livestrong
    4
    Thanks for the response. I have replaced the breather tubes and I don't get a more than normal amount of oil recoil out of the breather tubes that is common on softtails. Any other thoughts? It very well could be the small amount that collects in the air assembly.
  6. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    You say SE stage one,,, Does that mean the HD SE air?
    I think it to be Just a drip of Oil and condensation mixed that drips out of the air filter.. I don't know IF you oil the filter or run it dry??? I don't think it is a leak.
    If you oil the filter You probably use a bit much and it will collect on the bottom and drip.. Each time I'm back IN on My bike I always wipe clean the back-bottom open edge of air cover with a clean shop cloth.. Looking to see how much IF anything is there.. I do find Oil in a very small amount on occasion.. If left there It Will drip exactly like in your location.
  7. livestrong
    4
    Thanks, I'm thinking more more that is the case. I just cleaned the filter with K&N clean and it is drying. I will oil it with a small amount of K&N oil. This is the first time I've cleaned the filter, not sure about the previous owner. Do you recommend a product to return the black back to black?
  8. BUBBIE
    4,974
    125
    Another thought is ;; Does this happen after a wet wipe or wash.?
    If so It IS condensation or water-oil related drip off the air filter , I did have this once and a while on my bike.. Looking Just like you pict of the area under air filter, More of a stain than oil..
    Remember the oil On the TOP side of filter will drain down to the bottom ESP. if too much is used. So I would use less on the bottom side of air filter
  9. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    S100 engine brightener and Pig Snot are two very good products for wrinke black. Avail. at many mcy. stores (metric and HD).
  10. Jack Klarich
    Try a bit less oil when changing oil, Too much will cause carry over
