HELP...have a question on my SE tuner
Discussion in 'Electrical' started by harleykid1968, Apr 15, 2011.
  1. harleykid1968
    harleykid1968 Member
    8
    I have a screaming eagle race tuner kit that I purchased after installing a new set of Rush pipes on my 06 Heritage softail classic.
    Last year I removed the gas tank fix a dent after dropping the bike.
    The dent was fixed and repainted like original. I re-installed the tank with now problem.
    Ever since then, the bike just does not run the same.
    First of all, it takes multiple tries to start the bike
    Once it is running everything seems fine until I get on the Highway.
    Once I gun the throddle the bike hesitates, drops off, sputters but never stalls.
    I have to gradually speed up to avoid this.
    I was wondering if I should plug the bike back into my original tuner.
    Can I Check to see if all the values are ok?
    Does it sound like I need to re-tune?
    :small3d028::small3d028:
  2. Dr. Dolittle
    6,404
    118
    29
    Hang on a minute - you're asking all sorts of questions about your tuner but the trouble began when you had your tank off for repairs. I'd suspect an issue with a fuel filter, pump, hose, etc before I spent any time messing with my tuner.
  3. Hoople
    Hoople Account Removed
    7,198
    34
    I agree with Dr. Dolittle. The 1st thing I would be checking is fuel pump pressure. You can not read fuel pressure using the SEST. You must use a mechanical gauge.
    The last thing you want to do is "Re-Tune" the ECM or make corrections to a map. You will most likely wind up with multiple problems if you do.
  4. harleykid1968
    8
    Thank you guys, for the reply.
    I will take your advice
    thanks again. I will let you know how I make out
  5. mrwizz
    mrwizz Member Contributor
    52
    As the Doctor said, I think I would check the fuel filter first. Repairing and painting makes a hole lot of dust, if there was any sandblasting done that can really causes a fine gritty dust. If your tank was not sealed up completely during the hole repair that could cause a problem.
