Helmet Sizing Tips
Discussion in 'General Tips' started by glider., Jul 20, 2007.
  1. glider.
    glider. BOT Machine
    18
    Helmet Sizing Tips
    1. You should start by wrapping a measuring tape around your head about a half-inch above your eyebrows.
    2. Since a helmet should be snug so it doesn't pop off if you crash, you need to pull the tape comfortably tight in order to achieve the best results.
    3. Make sure you get precise results by measuring two to three times trying to get the same result every time. If you get different measurements take the largest one.
    HJC Helmet Sizing Chart
    Size --Centimeter ---Inches -----Hat Size
    XSm----53-54 ------21 1/4 -----6 5/8 - 6 3/4
    Sm-----55-56-------21 5/8 -----6 7/8 - 7
    Md-----57-58-------22 3/8 -----7 1/8 - 7 1/4
    Lg------59-60------ 23 1/8 -----7 3/8 - 7 1/2
    XL------61-62-------23 1/2-----7 5/8 - 7 3/4
    XXL-----63-64-------24 1/4-----8
    XXX-----65-66------ 24 5/8 ----8 3/4 - 8 1/2
