Hello from PA
Discussion in 'New Member Introduction' started by machineman66, Nov 28, 2015.
  1. machineman66
    machineman66 New Member
    Bought my first Harley, 2008 FXSTC, bike had 2100 miles when I got it, 11000 now. Seems to be chewing front tires, on my 3rd one now. Anyone have suggestions?
  2. HDDon
    5,561
    133
    236
    Welcome to the forum from Suwannee. The spec on your bike calls for an MU90-21. What tire are you running? In your other post you say that the tire is cupping and that you check the air pressure regularly. What pressure are you running? You could have an alignment issue and the manual shows how to check this. This could also be caused by how aggressive you ride. I would first check to make sure that the alignment is correct and I would also check to make sure the forks are not bent. I would also check the head bearings and check the tension using the fall away test.
  3. Joyflyin
    Joyflyin Experienced Member Staff Member Moderator
    5,823
    133
    208
    Welcome aboard, glad to have you here. :ws
  4. Jeff Klarich
    4,843
    103
    496
    :wce From the Rocky Mountains.
  5. fin_676
    5,788
    153
    287
  6. geezer
    geezer Senior Member Contributor
    1,709
    68
    73
    Welcome aboard from Canada. :)
  7. jamesearl
    jamesearl Senior Member
    1,894
    223
    Greetings,is it a 21 in fr.tire?
  8. coopernicus
    coopernicus Junior Member Contributor
    973
    98
    welcome from southeast Illinois!
  9. tourbox
    tourbox Senior Member
    1,902
    173
    Welcome from So. Texas. I agree with HDDon statements.
    tourbox
  10. Jack Klarich
    Welcome to The Forum :s
