Hearing a little "click" when i squeeze the brake, what could it be?
Discussion in 'Softail Models' started by Rafaelw, Apr 8, 2014.
  1. Rafaelw
    Rafaelw Member
    50
    I noticed a small clicking sound when i apply the hand brake when riding, i cant figure out where its actually coming from. it happens all the time when applying the hand brake the first time, when slowing down, if i drive again from a stop and go through a few gears, then go to use the hand break it does it. it does not happen when using the clutch or foot brake. Does anyone know what this may be? Besides that, man it felt good riding for the 1st time , here in SE Wisconsin this last weekend.
  2. hillbilly81
    hillbilly81 Active Member
    368
    do you have ABS on your heritage?
  3. Rafaelw
    Rafaelw Member
    50
    No sir i do not have ABS.
  4. Harttoo
    Harttoo Senior Member
    2,144
    143
    Front brakes replaced recently?
  5. Rafaelw
    Rafaelw Member
    50
    No sir, brand new bike, bought last June, not even 5000 miles on it yet.
  6. Harttoo
    2,144
    143
    Time to take it in for warranty.Let Dealer figure it out.:)
  7. Jack Klarich
    Warranty work, could be as simple as a brake light switch, or noisy floating rotor
  8. Rafaelw
    Rafaelw Member
    50
    "UPDATE" to my tread about Clicking noise when applying hand brake.
    So i took my bike to service, they told me that they had a few 13 Heritages come back for warranty work having to do with the master cylinder, they said it wasnt made an official recall, but did have a hand full of bikes come back for that reason. anyways after riding a bit i did notice it was wet around the master cylinder the brake fluid was not leaking out , but was getting wet around by the gasket. I called them just to inform them of what was happening. My appt is next Tuesday, ill find out what is going on then.
  9. hillbilly81
    368
    Re: "UPDATE" to my tread about Clicking noise when applying hand brake.
    good deal.. I hope they take care of it free of charge
  10. Rafaelw
    Rafaelw Member
    50
    Yes sir, they said its a warranty issue. No charge.
