The stock header pipe is about 30". Many tests made by several groups confirm this length as being very nearly the best for all-round performance. Shorter (less than 27") and longer (over 32") header pipes significantly reduce peak power output, throttle response and over-all performance in general. An exception to this "rule" are a couple of the high performance 2-into-1 systems which work very well with longer (and un-even) header pipe lengths. Stock Harley header pipes are near-perfect in diameter and length.
