Head Breathing
Discussion in 'Harley Davidson Extreme Modification' started by 90FXRS, Jul 12, 2012.
  1. 90FXRS
    90FXRS Junior Member Contributor
    462
    10
    On modified motors, high horse and torque, will more horse and torque be generated venting the heads on a twin cam to atmosphere or breathing through the intake?
  2. R_W_B
    R_W_B Senior Member
    2,425
    23
    I'm guessing the heads, but check with some of the more known builders for a definite comfirmation. I don't think Darkhorse does anything but cranks but they are a division of Hoban Brothers which offers a complete machine shop service. They might could give some insight on that.
    Hoban Brothers Cycle Service
    Also I know that Rev-Performance does head work so they could give some insight on that.
    Twin Cam Cylinder Heads
    I don't think they polish heads anymore. That went out years ago once they discovered the rough surface on the ports helped atomization to the point that the friction was a mute issue. But they definitely still port them.
    Also if you call this guy on the phone ( you will have to leave a short message and he will call you back) he is Mr. Harley knowledge when it comes to performance. His shop is only 40 mins or so from my place. He knows all about cams, porting etc and the dyno results thereof.
    http://www.docsperformancetuning.com/
  3. dolt
    dolt Senior Member
    2,185
    103
    342
    If I understand your question correctly, the answer is venting the heads to the atmosphere or intake will have no impact on HP/TQ. Having said that, common sense should tell you that venting crankcase oil mist back into the combustion chamber has some negative effects that are eliminated by venting to the atmosphere.:bigsmiley12:
  4. 90FXRS
    462
    10
    That was what I was thinking. TCs breathers do a better job of removing oil from the mixture than the older Evo-style breathers, but there is still some in the mix.
  5. R_W_B
    R_W_B Senior Member
    2,425
    23
    Oh I obviously misunderstood your question. I thought you meant opening up the ports some.
    Some guys rig up a catch can on their bikes. I've seen this done on cages also. It really doesn't have any measurable effect on power (as previous post said,) but it runs a little cleaner. In the real old days we just had valve cover or rocker breathers. But these tend to spew a fine oil mist out and is a constant cleaning issue.
  6. the draggin
    the draggin Active Member
    151
    It would seem a real benefit to vent to the atmosphere if you are using synthetic oil since it does not burn like "dino" oil. If I was going for full power potential I'd vent to the atmosphere, just my two cents........
  7. FLTR2008TRIKE
    FLTR2008TRIKE Member
    45
    There is no power gains with a vent system to the outside. With that being said, you gain a cleaner combustion chamber which will aid in keeping the carbon build up down.
    I run a catch can system on my 117"
  8. FishHunter
    FishHunter Active Member
    134
    No.
    Some folks have had us drill/tap for 1/2-13 breathers as were in the Evo's.
    Never have witnessed any dyno evidence of gains either way.:)
