SE6A
I have a 99 evo, that has developed a battery charging issue.
I tested the output from the stator which is good, inserting my meter test prongs in the plug holes from the stator.
I was advised it was the voltage regulator, so got a new one, and fitted it, but no luck.
it seems to me from the voltage tester that if the prongs were not inserted fully it doesnt read, and I think the plugs on the new voltage regulator just are not reaching fully.
obviously these are the same length as the old one, has anyone had this issue before?
if not, then a Stator replacement I guess!
