Handlebar damper kit for 04 and up Sportster
Discussion in 'Sportster Models' started by garyhdxlc, Dec 31, 2008.
  1. garyhdxlc
    garyhdxlc Member
    44
    I see in my new JP on pg 788 they show Damper kits for Sportsters from 73 - 09. I know that starting in 04 and up the handlebar risers are solid mounted to the upper tree. So how would a damper kit go in the top tree when they are solid mounts? I called up JP customer service today, a guy named Mark, said he didn't know for sure about the 04 and up, but he would look in to it for me, he just sent me this e-mail.
    Quote. Sir,
    I'm looking at the bushing set - p#500-314 -and it does not come with a nut. The set will fit, with a nut that will a 1/2 - 13 coarse thread. An alterantive to this is to go with p#5000021. These bushings are polyurethane and you can use your stock riser bolts. The difference between the two bushing sets are first set will have a little extra play and the latter will be a bit more stiff. Thank you... un-Quote.
    So has any of you ever put a damper kit on a 04 and up and if you have, how dose it fit in to the 1/2" hole in the upper tree?... Thanks.
  2. NEWHD74FAN
    8,191
    98
    19
    The 2004 Sportster was the first year the model had rubber engine mounts added. I have a one piece riser and handlebar solidly mounted and have no problems with vibration. One of the main reasons why I purchased this model year, was the low vibration, as well as the dual disc brakes and low maintenance cast wheels. I did put on a 2005 4.5 gal tank and had to change the seat to accomodate.
    Are you having a problem with vibration or front end shake that you believe this damper would fix? :57:
