Hand Sprayer Trick
Discussion in 'General OFF TOPIC' started by Webbtron, Apr 13, 2012.
  1. Webbtron
    Webbtron Banned
    583
    If you are like me you have about 5 worn out hand sprayers for the yard, to spray weeds for example. Well I found out that if you have an air compressor you can remove the wand end of the spayer and using your air compressor you can charge the sparyer by blowing air back into the tank, even through the handle. So you don't have to pump the thing up 50 times a minute. This is for the cheap folks out there tired of planned obsolesces.
  2. HD4ME!
    HD4ME! Active Member
    281
    Thanks for the tip! Gunna have to give this a try this weekend.
  3. oldhippie
    oldhippie Senior Member
    1,120
    68
    41
    Thanks for the tip.
    I'm not cheap, I'm frugal:D
  4. harley@16
    harley@16 Junior Member
    483
    5
    remember, pump cans like that aren't designed to hold 125 psi:p
  5. R_W_B
    R_W_B Senior Member
    2,425
    23
    I spray a lot of vegetation killer around stuff since I don't like the stains the weed wack leaves. A few yrs ago I bought one of those 3 gallon back pack harness sprayers at Home Cheapo. It's great, I just pump the wand every now and again while I'm spraying. Usually one fillup does my whole acre.
    I do have to set it on my truck tailgate to put it on though.
  6. Webbtron
    Webbtron Banned
    583
    Yep approach it more like you are filling your air suspension.
  7. Iceman24
    Iceman24 Well-Known Member
    3,266
    23
    Might have to give this a try...sone used my sprayer last fall on deck (cleaner) & I noticed he didn't rinse very well. Gotta love the "cheap" labor...;) Maybe I'll ask for a new sprayer for Father's Day..??
