Posted by "Chopper"...
GLOVE BOX DOOR/HINGE
REMOVAL
1. Remove the outer fairing.
2. To access glove box door fasteners, pull out screw cap cover below hinge.
3. Holding locknuts at front of inner fairing, loosen hinge screws (T25 TORX).
4. Hold glove box door closed as hinge screws are completely removed. If not held closed, door will pop open as spring loaded hinge is released and door may be
dropped to the floor.
5. If hinge replacement is necessary, remove plastic barrels to release hinge from door.
INSTALLATION
1. Place spring inside hinge inserting spring pin into closest hole. With coil and one spring pin positioned inside
hinge, second spring pin is outside.
2. Place hinge into position capturing free end of external spring pin between ribs molded into glove box door.
3. Install plastic barrels to hold hinge in door. Slot in barrel prevents interference with spring pin installed between ribs of door. Push barrels in until tight.
NOTE
Install new glove box door bumpers in inner fairing if damaged or missing. Insert tail of rubber bumper into hole, and moving to front of inner fairing, pull anchor through hole.
4. Place glove box door into position against inner fairing. Holding lock nuts (with flat washers) at front of inner fairing, tighten hinge screws (T25 TORX).
5. To conceal glove door fasteners, snap screw cap cover into place below hinge.
6. Install the outer fairing.
REMOVAL
INSTALLATION
NOTE
