Stormrider51
Glider,
Yesterday I noticed that the left rear turn signal light wasn't on. I figured the bulb was blown but today I did a more thorough check and I'm scratching my head. When I first turned on the ignition switch the light came on but then went out. I switched the bulbs between the right and left and the bulb is not the problem. I should mention that the turn signal lights have the set up where they get brighter along with the brake light when the brakes are applied. So the right light is lit normally but the left is dead. It does not come on when I apply the brakes but it does flash when I hit the left turn signal. Any ideas? You might save me a trip back to the dealership.
Thanks,
Storm
Thanks,
Storm
