free website stats program Gday from melbourne Australia | Harley Davidson Forums
Scratcha
G'day all, thanks for the invite, ive got a "06 FLHR roadking, love it, its my first Harley.
Recently had to fit the stock type pipes to it as I was reported for being too loud and need to have it tested to avoid a fine.
I noticed after fitting the pipes, its developed a vibration on deceleration. Im not sure if I now noticed it because its so quiet, or it has just started as a coincidence.
It seems to be less obvious if the clutch is pulled.
What do you recon?
Welcome from Spokane Washington..
Recheck the belt adjustment, maybe a little loose and causing the vibration.
Welcome from NW Indiana in the Good Old US of A. The best advice that anyone can take is "what was the last thing that was done before the problem began"!!! It works no matter what you are trying to fix. Go over everything that you touched.
Welcom from south Texas.
Look for some contact between the exhaust and the frame.
