Gasoline question
Discussion in 'Touring Models' started by anjumkha, Apr 22, 2011.
  1. anjumkha
    anjumkha Member
    What grade gas to use for 2007 Electra Glide?
    Thanks
    M Khan
  2. 01 rk
    01 rk Active Member
    318
    Minimum of 91 octane, 93 is better.
    Some Shell gas does not have the ethanol in it, using this is the best.
  3. Iceman24
    Iceman24 Well-Known Member
    3,266
    23
    Mostly run 91 octane, but try to fill w/93 whenever I find it (rare).
  4. glider
    93 in everything being it's poor quality with ethanol nowadays.
  5. gusotto
    gusotto Junior Member
    604
    38
    13
    I use the highest at the pump I can find.
    Usually 91-93, depending on the station/state I happen to be in.
  6. sharpscuba
    sharpscuba Banned
    945
    I use Mobil 93 octane if at all possible in my 07. Kwik trip is my second choice as they will stand behind their gas. If the gas creates a problem with your engine they will cover the repair cost.
  7. dbmg
    dbmg Guest
    That just shows you how intolerable to fuel additives the electronic sensors have become...
  8. Jack Klarich
    Every one should read the manual cover to cover there is a lot of info there , Strange I think not I too read manuals and every thing in between how else are we going to learn JMO:s
  9. oldhippie
    oldhippie Senior Member
    1,119
    68
    40
    DITTO that, definitely nothing strange about reading the manual. Reading the manual should be one of the first things you do to get to know your ride.
    That along with the service manual and join a great forum like this to get help with deciphering anything that you may not quite understand or just need a little boost to prompt you to do-it-yourself..
  10. HDSickness
    HDSickness Banned
    418
    Problem is you go to put premium(91 here in CA.) in and the guy before you used regular(87) so the hose is still full of 87 how much 91 are you really getting? That's why I try to only fill when I am really low on fuel, maybe I will get more 91 that way.
