Gaskets-Overall
Discussion in 'FXR Models' started by Jonk777, Dec 2, 2014.
  1. Jonk777
    Jonk777 Member
    39
    Hello, to all Hoggers out there. Who makes the best base and head gaskets for a evoulution engine. Are steel base gaskets the best. I need some input, from those that have been there and done that, to make the Hog keep squilling. Thanks
  2. Jack Klarich
    Check Cosmetics, I used Barnetts steel base and copper head gaskets before with good luck. The Cosmetics are much better, no need for spray copper coat
    Harley Davidson Forums
  3. Bodeen
    4,647
    73
    222
    Ill second the Cometic. Once you figure out what you need, be sure to check amazon for price. You'd be surprised at how much you can save...
  4. fin_676
    5,789
    153
    287
    I have used stock gaskets on base and head on some of my evo bikes with no problems gasket leaks occurred when the bikes were in my possession for a short time and may not have been properly warmed up prior to riding by previous owner
  5. dolt
    dolt Senior Member
    2,185
    103
    342
    CYCO gaskets are MLS, same as Cometic but about half the price. Have used them for several projects with no issues.:s
  6. HDDon
    5,562
    133
    236
