gas tank interchangeable?
Discussion in 'Softail Models' started by paradunks, Jul 3, 2010.
  1. paradunks
    paradunks Member
    Is a gas tank made for a carburated model adaptable to a fuel injected model? I.E 2003 carb fatboy tank to a 2005 heritage efi?
    50
    There's a fitting available that will cross them over the opposite way.
  3. NEWHD74FAN
    8,191
    98
    19
    Personally I would have to ask the reason...Why? As TQ and others have said in the past, all it takes is money and time...but then why not get an identical tank and have it reworked, if it is finish or paint, capacity or a customized profile it can all be done without pulling your old tank until your ready. We do want to continue riding while we contemplate what mods are to be done...right?
    The issue is not the tank or so much as fitting I would think, but the submersible fuel pump that has it's own mtg and access panel, as well as the electrics feeding it as designed, along with fuel level float assembly matching up to the center harness connector in the frame and tank tunnel area. Need a little more clarification before we can weigh in here.
