gas smell
Discussion in 'Touring Models' started by tommys, Aug 23, 2010.
  1. tommys
    tommys Member
    31
    2005 road king, stage 1 kit, se slip ons, 95 in. cams 28000 miles, fuel injected
    smell gas when walk in garage where bike is stored, gas smell when idle, people behind me smell raw gas out the exhaust
    bike idles a little rough but runs good and no loss of power or fuel milage
    any ideals where to start to find problem or is there even a problem
  2. tommys
    tommys Member
    31
    changed plugs about 4000 miles stock fueler
  3. tommys
    tommys Member
    31
    this is correct but this just started a couple weeks ago
  4. Jack Klarich
    Leaky injector?
  5. tommys
    tommys Member
    31
    going to run compression check one night this week
    how can I check the injector
  6. NEWHD74FAN
    8,191
    98
    19
  7. Hoople
    Hoople Account Removed
    7,198
    34
    Something is not right there. Get a good hi intensity light and look around for fuel dampness. Check the fuel cap seal, crossover line, quick disconnect hi-pressure line etc. You should not be smelling fuel raw.
  8. tommys
    tommys Member
    31
    thanks guys think I've found where the smell is coming from. Think its coming from fuel cap seems it has a bad o ring
  9. cowboywildbill
    cowboywildbill Active Member
    231
    I hope that is your problem, it would be the quickest and easiest one to fix.
    A bad cap lets the fuel go out the overflow vent line, that would explain the smell.
  10. ricktara
    ricktara Member
    18
    if that doesn't fix it, check the tank vent line. On my 07 street bob the little hose split under the center console cover over the tank. smelled of raw fuel but could never see a leak until I took that apart.
