FXDL Check Engine Light
Discussion in 'Dyna Models' started by vr57c9lm, Jul 24, 2007.
  1. vr57c9lm
    vr57c9lm New Member
    3
    I just changed out my clutch cable and with that my oil filter and all the fixings. Now I get a check engine light that comes on and goes off constantly. What could be the problem and can I fix it?
    56
    Here's all the info you need to pull a code out of your 01 dyna lowrider.
    If it goes on but doesn't stay on, it's a historic code (something that happened in the past) If it stays on while riding, it's something setting a code that is still present.
    Did you disconnect the battery at all?
    If it is a historic code, it will reset itself after 50 start & run cycles of at least 30 seconds each.
    If you give more specifics on the bike it will make it easier to diagnose a problem in the future.
    http://www.hdtimeline.com/diagnosti...elated/729-00_03_hd_codes_and_activation.html
  3. vr57c9lm
    vr57c9lm New Member
    3
    2001 Dyna Lowrider, V-Twin 88, 5 speed transmission.
  4. glider
    56
    Now there ya go, all the info needed to diagnose a problem:D
    Same scenario as post #2 above.
  5. vr57c9lm
    vr57c9lm New Member
    3
    Disconnected the battery and reconnected. Turned ignition on and had check engine light, it than went out. Started engine and it came back on for about two seconds. Went for a test ride for about six miles and the light never came on. Thanks for all your help. I'll let you know what the outcome is after 50 starts.
