front wheel remval
Discussion in 'Wheels' started by jorge72, Mar 24, 2011.
  1. jorge72
    jorge72 New Member
    Just bought a 1992 Heritage Softtail, would to know how to remove front wheel?
  2. dbmg
    dbmg Guest
    Re: front wheel removal
    And remove caliper, before removal of axle.....
  3. FLST
    FLST Active Member
    248
    4
    Invest in the factory service manual. Best thing you can get for your bike if you are doing your own service.
  4. fin_676
    5,779
    153
    285
    Also take note of the position of any spacers and washers so that you get them back in the correct location
    take note there is a wee tab on the speedo drive it fits into a wee slot on the brake rotor on reassembly
  5. steve saunders
    steve saunders Member
    45
    cleaning the axle and applying a thin coat of never sieze before installing will help make the removal easier next time. a great manual is the clymer manual. id be lost without it!
  6. harrly
    harrly Member
    14
    It's a good idea to put some support under the rear wheel when it's up on the lift. Removing the front wheel can get a little scary and become a bit unstable.
