Wavesearcher
Hi, my 2 post here
I have a 93 sportster. The brake kaliper are making sounds that resembles nails inn a tincan when I hit bumps in the road. Is this normal? It makes the same noise if I hit it. The bolts are tight.
The floating pad in the calliper is held in place on a floating frame by a spring clip
if the pad is not fitted in the frame correctly with the spring holding the pad in place then the frame and pad can rattle around a wee bit
Your choice on that one
take out 2 bolts and the calliper is off takes a few minutes to check
if it were mine and i wanted to ride in the morning i would be out in the shed at this time pulling the calliper off to check
