Front Axle Torque
Discussion in 'Softail Models' started by lorne, Aug 18, 2010.
  1. lorne
    lorne Senior Member
    2,426
    58
    22
    i have a 98 softail custom with a fatboy front end i need to re torque my front axle nut. the books says 50lbs (with the stock front end) the dealer says 70lbs (with the fatboy front end).:33:
    any suggestions?
    thanks in advance
  2. fin_676
    5,777
    153
    285
    My service manual is for 91/92 and it states 50lbs for the front wheel and it has a different section for each of the front wheel types that can be fitted but all read 50lbs
    so from that id tend to think your service manual should be correct
  3. lorne
    lorne Senior Member
    2,426
    58
    22
    fin
    thank you....50lb it is
