Front axle nut torque
Discussion in 'Wheels' started by Goose67, Aug 3, 2011.
  1. Goose67
    Goose67 Member
    21
    23
    I took my front wheel off 2007 FXSTC and got fresh rubber put on. need info on what to torque axle nut to. Tried a search and could'nt find anything. Any help would be appreciated.
    Thanks, Goose
  2. Breeze3at
    Breeze3at Well-Known Member
    4,926
    224
    2007 FLHTC specs. are axle nut 50-55 ft.lbs., fork cap bolts 132-180 inch lbs. There is also procedure to align fork leg before tightening clamp bolts. Softail specs may be the same, but I'm not sure.
  3. glider
    50
    50 TO 55 ft. lb. per the manual for that bike.
    I suggest you get a factory manual for that bike.
  4. lordharold
    lordharold Active Member
    191
    all but flstsc front axle torque 60 -65 ftlbs according to 2007 manual
