Front and Rear Oxygen Sensor Codes
Discussion in 'Engine, Fuel and Exhaust' started by motoman41, May 6, 2015.
  1. motoman41
    motoman41 New Member
    4
    Hi Everyone,
    This is my first time so thanks for your help.
    I bought a 2006 FXSTI in March. I just started riding it and the engine light comes on.
    The diagnostic comes up code P0154 rear oxygen sensor inactive and P134 front oxygen sensor inactive.
    I reset the codes but they come on after 1 mile.
    From what I understand the 2006 does not even have oxygen sensors on it.
    The bike does have screaming eagle exhaust.
    since I bought it used I do not know if any thing else was done to the bike.
    It only has 4000 miles.
    Any help or suggestions would be greatly appreciatet.
    Thanks, Rick
  2. cdn-bigfoot
    cdn-bigfoot Junior Member
    645
    Rick, look at the pipes several inches down from where they bolt to heads. Are there wires coming from plugs that are about the size of spark plugs?
    I'm pretty sure the 2006 FXSTi would have originally come with O2 sensors. If someone has done away with them it would explain your codes.
  3. tourbox
    tourbox Senior Member
    1,888
    168
    In '06 only the Dyna's had the 02 sensors. The rest came with 02 sensors in '07. I wouldn't think you should that code unless some download is causing it. Do you have some type of fueler on it?
    tourbox
  4. motoman41
    4
    Thank you.
    I will check when I get home.
    I appreciate the help.
    Rick
  5. motoman41
    4
    I am not sure. Thanks for the help.
    I guess I will take it to the dealer to check it out.
    Again thank you for yor help.
    Rick
  6. Jack Klarich
    Check your VIN, 07 models all had o2 sensors only the Dynas did in o6
  7. Jack Klarich
    [​IMG]
    Here is your main wiring diagram I see NO wires for O2 sensors for your bike
  8. motoman41
    4
    Thank you.
    It must be something with the computer
